BFH or spacer
Old 01-09-2013, 01:19 PM
Taylor.o1's Avatar
Default BFH or spacer
I just got a set of chrome z06 rims, the rears are 18x10.5 with 58 offset. the sticky says ill need the BFH mod or a small spacer. The way i see it the BFH mod is free and easy. any pros to using small spacers insted?
im runing G force drag radials 295/35/18 if that makes a difference
Old 01-09-2013, 01:54 PM
Undertow74's Avatar
Me personally, i don't like the idea of using spacers on the rear wheel where all your torque is coming from. Especially if you are using the stock wheel studs. I would just BFH, and see where you are at and then go from there. If you do go the spacer route i would for sure upgrade the wheel studs to a set of longer ARP's
Old 01-09-2013, 02:02 PM
SMOKNSS's Avatar
I would use the BFH mod before running spacers. I dont like spacers.
Old 01-09-2013, 02:18 PM
Taylor.o1's Avatar
Thanks! im glad to hear the free way is the preferred way, too bad that dosent happen more often.
Once it stops raining ill pull out my hammer and have at it.
Quick Reply: BFH or spacer
