Anyone running a 3" narrowed rear w/ 5.5" BS 10" wheels?
(Reposting from here)
Anyone? Pics? Opinions?
Reason I ask is I'm going to get a 3" narrowed rear, and I want my tire to be pretty tucked in. Gunna run a 275 / 60 / 15 on a 10" wide wheel. Wondered if anyone ever ran a 5.5" BS in this scenario.
My friends and I ALL run 15"x10" wheels with 5.5" backspacing on rear ends narrowed 3" per side.
My junk (15"x10" Weld RTS's with 5.5" backspacing and M/T 295/55/15 Drag Radials):
My friend's T/A (same wheels and tires as mine):
My other friend's T/A (15"x10" Weld Prostars with 5.5" backspacing and 325 Drag Radials):
Hope that helped.
Hope that helped.
Yes that is standard, but it looks horrible because it sticks out so far. I currently have a stock rear with a 10" wide wheel and 7.5" BS and I don't like it. I want my wheel / tire tucked in a bit like the ones you see above.
I run the same setup as above. 3" narrowed per side with a 15x10 5.5 b.s. wheel on 295/55r15 mickey thompsons. I run a .25" spacer only because when i turn the tire rolls into the inner wheel well and barely scuffs when i dont run the spacer, i could probably massage the fender a little more and clear perfectly.
4.5'' b.s. like others have said, sticks out to far.
Bogart RT wheels
15x4 front and 15x10 rear.
The rears are offset for a rear that has been narrowed 3" a side.
Rear tires are M/T ET Street Radial 325/50/15.
i also have 10" rim with a 7.5 B.S and there's no way you have a nother inch in go IN , b/c i have maybe 1/8" before the tire hits the inner wheels house and i had to bang in the back seat belt area .. and my rear is centered with an adjust panhard bar ... your also saying(not that anyone would) that you can fit a 10" rim with a 8.5 B.s ON YOUR CAR ?
LS1Tech Premium Sponsor
Hope that helped.
Hope that helped.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
