weld drag lites/pro stars?
looking at getting some 15x10s for the rear to sticks some dr's on for a few track passed this year. first question will they go one without any grinding. to what backspacing should i get
I recommend your rear brake pads be fairly new when testing fitment. You will have to grind a bunch. And remember when going to a sticky tire at the track that when your tire doesn't break loose, the next weakest link may--especially with a M6 car.
with the prostars or draglites you will be grinding a ton off your calipers. i did it this past fall so i could use my buddys draglites. you will have to cut bumpstops off also most likely
get ahold of beefcake racing and see if he has any dark stars left. a bunch of just got 17x4.5 fronts and 15x10 rears for 520 shipped with lugnuts and caps. his phone number is listed in the posts.username beefcake. or go beefcakeracing.com. i texted him at 1030pm to get my set abd he answered right away, they bolt right on require no grinding
Captain Double Post
Brush a lil paint on your calipers,put wheel on and spin,take wheel off,that will give ya a good idea on where to grind,i have prostars on mine,longer studs/spacers /grinding are pretty much a must with that setup,there are other wheels that just bolt on they just cost a lil more, but ya can pick up prostars dirt cheap,once i get new wheels ill pretty much give mine away lol,imo spend a lil more even on racestars ya might have to grind just a lil, but it wont be as much,as for saftey of driving on grinded calipers,i have many miles on mine and there fine,but i agree fit the wheel with new bpads,
