Wheel spacer questions. Am I crazy?
Old 02-14-2013, 02:20 PM
silversrtman's Avatar
Default Wheel spacer questions. Am I crazy?
Im installing CTS-V calipers under my 17" C4 ZR1 wheels. You need a 1/4" spacer to do that according to the how to thread. I want a hubcentric wheel spacer because I dont want to deal with any vibration issues, theres nothing worse than a shaking steering wheel, plus I have enough other vibrations lol with this car. Does anyone know of someone that makes a direct hubcentric 1/4" wheel spacer with our hub bore diameter of 70.3mm I think it is? I have been searching and I cannot find anything.
Also if I cant find anyone that makes one I was thinking of making some spacers on my own, except everyone that I tell that I am going to make my own spacers looks at me like I have ten heads. Am I crazy for wanting to make my own? It'll be a PITA but other than a lot of tedious measuring and cutting I dont think it will be that bad at all. Any help would be appreciated. Thank you.
Old 02-14-2013, 02:23 PM
Undertow74's Avatar
if you have a cnc or a lathe, go for it make your own spacers. just google wheel spacers, click the first link.
babbage1109's Avatar
If you look at the thread. It shows you what spacers to get. They come with new wheel studs and the hubcentric spacers. You need 2 pairs. Advance auto parts sells them. They are good pieces I run them on my car without an issue.
Old 02-14-2013, 04:31 PM
I dont have either but I do have confidence in my abilities
I was referring to the thread fitting the brakes under 17" wheels. In that thread the op runs a 1/4" non hubcentric spacer. I dont want a wheel adapter spacer like the one in the thread youre talking about. Thank you though.
Old 02-15-2013, 12:32 AM
What kind of wheel spacer are you talking about then?
Old 02-15-2013, 06:26 PM
Empatho's Avatar
He is probably talking about the eibach spacers that are mentioned on one of the cts-v brake threads. I use some eibach spacers myself and I have no vibrations or problems with them, they are good quality spacers.
Old 02-15-2013, 08:48 PM
Those are the ones I am talking about. I run them and haven't had an Issue.
Old 02-15-2013, 11:56 PM
Thanks for all the replies guys. I was looking for some spacers that fit the hub bore perfectly so they don't move around and cause any problems...the eibach ones are too big, I just need 1/4"....I actually ended up getting exactly what i was looking for from Blaine fabrication.com.
Quick Reply: Wheel spacer questions. Am I crazy?
