Wheel Spacers, Safe??
So, I recently put on 315s on the back of my Z28. I drove the car on the highway about 1 week ago and was accelerating through an on ramp and there was some rubbing.
I BFH'd the inner fender and there is about 1/4 inch of space from the tire to the inner fender at the time of this rubbing. I will be buying a bigger hammer but I really don't think I will get more than 1/8 inch more. What are some of your guys clearance??
I am also planning on renting the fender roller tool in March and rolling my fenders to nail that problem.
So if all else fails, my last option I guess is to run a rear wheel spacer.
Are these safe? What would be a safe size to use? I've heard to use a "hub centric" wheel spacer if I am going to do so.
I don't want to jeopardize my life or others for this however.
I mean I know it centers the rear end. But isnt the rear end already centered? Wouldn't there be serious problems if it wasnt? lol
I guess I just don't understand.
The car is lowered on BMR Springs. It did have the rear isolators out (hose mod) when it was rubbing put they are being put back in.
Yes, the rear is basically centered, BUT when you lower it you're no longer centered, plus there is a (relatively large) tolerance from the factory on where "center" is. With the factory wheels and tires you have a lot of wiggle room, but start packing those wheel wells full of rubber and you need to be more exact.
If I have to though, What about the spacers?
Depends on how thick you go. If you're only doing 1/8 that is very unlikely to cause a problem. Might not be a bad idea to get a little stronger studs. But the issue you could run into with a spacer is running the tires into the lips of the wheel wells, so only do as much as necessary. Most people don't need spacers to fit 315s however, although I'm not sure what backspacing they have. What wheels?
The rear wheels are just 17 x 11inch wide black deep dish ZR1's with the 56mm offset, I know its in the 50s just not 100% sure.
I was also thinking about the same situation of the fender lip cutting into the tire with the spacer which is a no go, if 1/8 inch does cause it to cut the tire.
Damn, well if it rubs after the PHB I am going to beat the hell out of the inner fender and just hope for the best. Wish I had a friggin T/A and I wouldnt be having these problems lol
