??? possible to run taller tires in rear w/o abs freaking out?
Old 03-15-2013, 10:21 AM
Khaalathas's Avatar
Default ??? possible to run taller tires in rear w/o abs freaking out?
Just wondering if the computer can be programmed so that if I were to run 275/40/18 in the rear 26.7 height and 245/45/17 in front 25.7 height that the abs and traction control system could be made to not error.
just an FYI I understand that without a potential reprogramming that it will freak out so I am specifically asking if the computer can be reprogrammed at a dealer so that it wont freak out as I have some corvette size setup in 17/18 staggered that I want to run potentially.
Thanks in Advance.
Old 03-15-2013, 10:31 AM
Khaalathas's Avatar
Oh I forgot to say this but this is on a 2001 Camaro Z28.
Old 03-16-2013, 08:19 AM
Khaalathas's Avatar
bumpy bumpy
Old 03-17-2013, 05:37 PM
Khaalathas's Avatar
nobody?
Old 03-18-2013, 03:04 PM
willizm's Avatar
I pulled the ABS fuse so that mine wouldn't freak out, but i'm curious if this could be changed in HPTuners too since I have a copy of it.
Old 03-18-2013, 03:37 PM
Khaalathas's Avatar
yeah hoping more for a solution that allows me to keep my abs and traction control rather then just making the light go away
Old 03-19-2013, 10:21 AM
Brennen's01SS's Avatar
From my experience you can have a difference of 1" front to rear. I'm not sure if it could be reprogrammed to accept a taller tire
Old 03-19-2013, 03:17 PM
BadCompany VP WS6's Avatar
Does your TCS come on and off all by itself?
Old 03-19-2013, 04:40 PM
Khaalathas's Avatar
havent gotten the tires yet just doing some preemptive problem solving as I've read several posts complaining about traction control and / or abs kicking in with staggered height tires installed.
Old 03-19-2013, 06:12 PM
00pooterSS's Avatar
I don't think you can change that, I pulled the fuse when I ran my 28's.
Old 03-19-2013, 06:56 PM
Dickie-311's Avatar
i'm wondering the same thing.. i'm going to be running 295-45-17 ( 27.2 " tall)
Old 03-19-2013, 09:13 PM
SparkyJJO's Avatar
I'm pretty sure that's all coded in the ABS system, not the main computer, so you can't just reprogram the tolerances with HP tuners.
Old 03-20-2013, 11:26 AM
Khaalathas's Avatar
very nice to get some answers finally but I hope your wrong dangit
Old 03-31-2013, 03:31 PM
LilJayV10's Avatar
Some handheld tuners will let you change your tire size/aspect ratio. That would probably be cheaper than going with HP Tuners.
Old 03-31-2013, 08:46 PM
SmokedOutZ28's Avatar
There is no option in HPT to modify ABS, HPT will allow you to change tire size for speedo function but thats about it.
I ran with a difference of 2'' from front to back on my 97 with no ABS issues but I do not have any experience with it on a 98-02 based F-body Yet!
Old 03-31-2013, 10:51 PM
1999transamls1's Avatar
I dont think 1 inch will throw it off, but I don't know a way to fix it if it does. Id be interested to know though so bump!
Old 04-01-2013, 12:59 AM
I8UR4RD's Avatar
What ABS?
Quick Reply: ??? possible to run taller tires in rear w/o abs freaking out?
