Why are the selling with different aspect ratios?
Old 03-22-2013, 07:38 AM
yukonblu's Avatar
Default Why are the selling with different aspect ratios?
I don't know a genius when it comes to tire sizes and am wondering if anyone knows why there selling these tires with different front and rear tire height/aspect ratios.
http://www.oewheelsllc.com/Wheels_3/...heels_Tires134
Front 40-17
Rear 35-17
Is this normal? I don't recall ever buying my tires like this?
Old 03-22-2013, 08:52 AM
TheSilverOne's Avatar
FRONT WHEEL SIZE: 17x9.5
REAR WHEEL SIZE: 17x11
FRONT TIRE SIZE: 275-40-17
REAR TIRE SIZE: 315-35-17
Old 03-22-2013, 08:59 AM
yukonblu's Avatar
I'm not sure I understand your post?
Shouldn't they both be 35-17? They are not staggered.
Old 03-22-2013, 09:16 AM
Sail Hatan's Avatar
no. the 35 and 40 is the side wall height in the form of a percentage of the width. iirc.
so the 275 tire. the sidewall is 40% of that 275. 315 tire, the sidewall is only 35% of that 315. if it was 40% that back tire would be taller that the front.
unless your running 4 same width tires, then it makes no sense. and two of them will be taller. what size tires are you trying to buy?
edit- looks like you are buying 17x11 inch wide rims for the rear, and 9.5 inch wide rims for the front. so my original post stands. same tire set up on my car.
Old 03-22-2013, 01:34 PM
Khaalathas's Avatar
lower aspect ratio would be to make up for a wider tire to keep the overall height the same on both tires
Old 03-22-2013, 02:48 PM
thunderstruck507's Avatar
the above posters are correct
a 35 series 275 width tires is not going to be the same height as a 35 series 315 because it is a percentage of width (35%), so to have tires the same approximate height front/back you need to vary the profile series
Old 03-22-2013, 02:50 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
275/40R17 = 25.7 inches overall diameter
315/35R17 = 25.7 inches overall diameter
The aspect ratio is a percentage to the width. 40 percent of 275 is the same as 35 percent of 315.
Old 03-22-2013, 02:52 PM
SparkyJJO's Avatar
The second number is a percentage of the width to make the sidewall radius.
Tire height = (tire width * aspect) * 2 + wheel diameter
40% of 275 is 110
35% of 315 is 110.25, so the radius is only 0.25mm taller. Overall tire height is only 0.02 inches taller.
If you had an aspect ratio of 40 for those rear tires, you'd be at 126, which is about 5/8 inch taller on the radius, or 1.25 inches taller tire overall.
Hope that helps.
Old 03-22-2013, 06:42 PM
yukonblu's Avatar
What the hell would u all do if u didn't have to answer all my dumb questions. I come from the jeep world where 90% of the time they use inches, front and rear always match, and most people use crager 15" steel wheels... In my neck of the woods anyway, and all we worry about is how much we can deflate our tires without them popping off the rim lol
Old 03-22-2013, 06:46 PM
Sail Hatan's Avatar
Lol yea, normal tires are stupid, I'm used to 35x12.50 15. Easy to read, lol.
Old 03-22-2013, 06:54 PM
SparkyJJO's Avatar
I'm keeping mine simple by sticking with the same size front and rear when I order my new wheels and tires, 275-40-17
Old 03-22-2013, 07:00 PM
yukonblu's Avatar
Probably get better wear out of them too, since you can rotate them and all
Quick Reply: Why are the selling with different aspect ratios?
