Question for the toyo tq guys
Old 04-30-2013, 09:43 PM
aaronware76's Avatar
Default Question for the toyo tq guys
Hey guys, I'm going to be ordering 315/35/18 tq's for my c5 dd wheels and my question is: can I get those tires and wheels to work on the rear of my ws6 without rolling the fenders? I will bfh whatever I need to, I'll cut the bumpstops but I just don't want to have to roll my fenders. I've got stock ws6 wheels on now with 315/35/17 nitto 555r's. I know the tq's are gonna be wider but only by less than half an inch. If I can't squeeze them in there without rolling the fender, I may go with something else but I really don't want to. Let me know guys. Any input is appreciated. Thanks.
Old 05-01-2013, 05:14 AM
Sail Hatan's Avatar
mine rub, I need my fenders rolled. hard cornering or with a rear passenger they rub. im gunna mess with my adjustable panhard bar, but pretty sure they already rub both sides. just more on the left. my 315 sumitomes didnt rub as bad as these. hopefully you arent putting these tires on the ws6 wheels, cause they're too big. Nittos are already pushing it, and theyre pretty narrow....
Old 05-01-2013, 08:28 AM
No, I've got 18x10.5 c5 chrome dd wheels from oe wheels to put them on. I've got an adjustable pan hard bar also. I'm at stock ride height, are you lowered sail hatan?
Old 05-01-2013, 08:50 AM
Sail Hatan's Avatar
I am lowered, about an inch in the back. So maybe you won't have too much of an issue. I'm gunna mess with the phb
Old 05-01-2013, 07:52 PM
Good luck. I hope that's all you need to do. I really want these tires for the grip but also they'll do a good job filling up my wheel well and not look ridiculous.
Old 05-01-2013, 08:06 PM
Super Hulk Smash
JakeFusion's Avatar
They rub on the inside? Did you cut the bumpstops? Those 50mm wheels are recessed too much for a TA. Try a 10mm or 3/8" spacer. That'll probably fix it as the TA has larger wheel wells than a Camaro, but the 50mm offset is not great. 38-45 is more ideal.
Old 05-02-2013, 07:52 PM
Anyone else? I think I may just order them and see what I come up with once they're mounted.
Old 05-02-2013, 08:26 PM
Sail Hatan's Avatar
My bumpstops are cut from 17x11 clearance. I think the fenders are my only issue. I still have been driving everyday.
Quick Reply: Question for the toyo tq guys
