Not sure, but fast way to find out is take some metal polish, hand polish the inner barrels and if it turns black, that means no clear coat. If it doesn't, then they are clear coated.
I finally got a wheel clean enough without abrasives to test and you are all correct. The barrels are not clear coated. Thanks for the info. It should make cleaning them a bit easier.
