air pressure on Hankook Ventus Sports 275 35 18?
Old 07-29-2013, 06:50 PM
black ttop's Avatar
Default air pressure on Hankook Ventus Sports 275 35 18?
I just put on my 18" Ruff racing wheels and Ventus Sport tires. I am not sure what air pressure to run in them, after storage they have between 36-39 psi in each tire. The sidewall says max psi is 51.
I am used to running 30-32 in my 245 60 16s on stock rims.
How much air pressure should I run?
rims/tires front 245 40 18 tires, 18x9 rims
rear 275 35 18 tires, 18x10 rims
Thanks!
Mark
Old 07-29-2013, 10:45 PM
black ttop's Avatar
I'm going to try out 36psi
Old 07-29-2013, 11:41 PM
99Bluz28's Avatar
I'm running 32 psi front, 30 rear in mine.
Old 07-30-2013, 10:13 AM
black ttop's Avatar
does the size of the tire make any difference in the air pressure you run?
Like more or less psi for a low profile, wider tire?
Thanks!
Old 07-30-2013, 10:48 AM
thunderstruck507's Avatar
mark the tire with flour or fine sand and then take a short drive, should be able to see where the contact patch is on the tread...I start high and drop it until I get even patch across the tread, otherwise wide tires tend to wear the centers pretty bad
Old 08-02-2013, 09:14 PM
black ttop's Avatar
Thanks for the info. I ended up with 32 in front and 30 in the back and that seems to work great!! Rolling flat too!
Thanks again!
Quick Reply: air pressure on Hankook Ventus Sports 275 35 18?
