Sneaky Tire Construction
Moderator
While shopping tires I got a whiff of something I think
is a sneaky trick. That is, tires constructed with a thin
"traction" layer over a hard "tread life" layer. So they
stick great initially, then not so great. I don't want this
kind of tire, I want traction down to the cords.
How can I be sure which tires are or aren't made this
way?
way?
The old Firehawk SZ50 EPs with Uni-T were the opposite. They had a layer that was harder on the outside, so as you wore it down and the rubber vulcanized with heat cycles it softened to preserve performance through the life of the tire. One of the best street tires I have owned. They were the regular tires, not the run flats though.
way?
way?
Although it might not be leaking out "trade secrets" tire companies might not freely discuss these traits about their tires, but maybe you could get some answers from one of the techs at Tire Rack. I know a lot of their guys run auto-x, so they should have the inside info...
Bridgestone/firestone calls what some of you are talking about dual layer tread. and its not for wear life, its so the tire maintains a consistent level of wet traction through its entire life.
I have never heard of a mainstream manufacturer who intentionally makes a performance tire that under performs. That seems like a great way to never sell a second set of tires.
I have heard of people who put the wrong tires or cheap tires on their car and expect miracles.
If you want a good tire then buy a good one, its not hard to figure out which ones they are.
If you give us some info on price range and size, Im sure we can give you some good recommendations.
