Big Effin Hammer......inner wheel wells.......opinions.....
For those of you have banged the **** out of the inner wheel wells....to its maximum without banging through the metal.
How much room in inches is that good for.....?
My plan is to widen a 10.5" wide OE rim to 11.5" wide. 335 tires.
Then use a 1" spacer with ARP wheels studs.
I'm wondering if that will be good so the tire does not rub the inner wheel wells after the BFH job......
Also, will it clear my LG Motors Sports LCA's......
Thanks for any info......
I had a nice surprise when doing this car a few months back. Hammered in the areas that hit (toward the front of the car around the area where the bottom of the backseat meets the seam of the inner quarter well), about the 4th hard hit it busted thru and I saw carpet. The car had a rust area about 6"x6" there after knocking all of the undercoating stuff off. There was NO sign of it under there either, so if your car has ever been north of Kansas on the map I'd proceed with caution. I'd done 3 other cars and never had this problem before. Now I have to cut out that section and patch it. Pain in the *** for something that could've been prevented with a little rust inhibitor and some new undercoating.
I BFHed to get 17x10.5"s (originally 17x9, widened toward the inside) with F1 GS-D3s and used a 5/8" spacer... I have approximately 1" before the tires hit the LCAs. Also, after priming and painting, then having it re-coated with that rubbery crap at Race Proven Motorsports in Delaware (they said it was OEM), there's still slight signs of rusting. I need to find a shop that's willing to mini-tub without chopping into the back seat area... then go wider.
I was gonna use a 3/4" or even 1" spacer with my 10.5" rims........I assume that wont take a crazy amount of BFH....?
