19" Tires Help. ASAP
Old 11-19-2013, 08:25 PM
atahtz28's Avatar
Default 19" Tires Help. ASAP
Hey guys, Im currently running 19" c6 rims on my '01 Z, along with 1.5 inch lowering springs and some spacers as well (I think 1") My current tire is 285/35/19. Now, i found an extremely good deal on some 275/40/19. Will they fit? Im worried about the profile of 40mm..
Old 11-20-2013, 01:46 AM
99Bluz28's Avatar
Your current tires are 26.85", a full inch taller than stock.
The 275/40/19 is 27.66" you might be ok in the rear, but not in the front that's close to a full inch taller that you current tires, and 2" taller than stock.
You should be running either a 275/30/19(25.50"), 285/30/19(25.73"), or a 295/30/19 (25.97") depending on your wheel width, these are all within the stock height range. now if you feel you need a taller tire with more sidewall height than I wouldn't go any taller that a 275/35/19 which is 26.58" tall.
Old 11-20-2013, 07:44 AM
atahtz28's Avatar
Sorry i should have mentioned my car is staggered with 18's on the front, so i'm only curious about the rear. I have new front tires already. So then i have 0.81" more with these tires, i'll have to check to make sure i have that much room.
Old 11-20-2013, 09:39 AM
69TA's Avatar
If you interested I have a nice pair of like new
295/30ZR19
Michelin ps2's for sale for cheap.
Old 11-20-2013, 01:07 PM
99Bluz28's Avatar
So what's the width on the rear wheels, and what size tire are you running up front?
Old 11-20-2013, 02:46 PM
atahtz28's Avatar
10.5 in the rear, and fronts are 235/40/18 or something, i do not need any fronts though.
Old 11-20-2013, 03:43 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
2 inches over stock is a lot of height difference I doubt it will work.
Old 11-20-2013, 05:56 PM
99Bluz28's Avatar
A 305/30/19(26.2") would be an option then, and have sidewall height within 1/10" of a 235/40/18, and a overall front to rear height difference of .8".
Old 11-22-2013, 11:00 AM
atahtz28's Avatar
Oh so thats why you wanted to know the front haha i didnt understand, but thats a good idea, there are lots of 305's around so i think ill look for those. Thank you for your help, i appreciate it
Old 11-22-2013, 12:36 PM
99Bluz28's Avatar
Yeah, I didn't want to recommend you a rear tire that has a noticeably shorter side wall, since it wouldn't look right.
Old 11-22-2013, 01:17 PM
johnLs1camaro's Avatar
yeah go with a 305, also there is no need for a spacer.. I have a c6 zo6 wheels 19x12 with no spacers!
Old 01-08-2014, 11:22 PM
01qwkz's Avatar
So what size tire did you go with? Pics?
Old 01-08-2014, 11:23 PM
01qwkz's Avatar
What did you run
Quick Reply: 19" Tires Help. ASAP
