Tires and speed limiter
I have a 98 Z28, with the tire code QF2- at the moment shes got some H rated all seasons on her. What were the stock tires, and if they arent the Z rated tires, what is the speed limiter?
The standard tire on the Z28 were a touring 235/55/16 with either a U(124mph) or H(130mph) speed rating (not sure). If you have the 125mph speedometer then from the factory it's set at 115 mph. If your car has the 125mph speedometer then it came with the standard tires.
