TSW Sochi
Old 02-03-2014, 02:45 PM
DemonicZ's Avatar
Default TSW Sochi
I've never seen these before today, must be a new model for 2014... they come in 18x9.5 with 39 or 40mm offset... will I be able to run these on all four corners?
Old 02-03-2014, 03:25 PM
Photochop's Avatar
http://www.1010tires.com/Tools/Wheel...ulator#Results
Put in a 9" wide wheel with a 56mm offset for reference and see what you get.
A couple good references for front and rear maximums are a 7" wide front with 0mm offset (17x7 Street Lite, just inside fender) and a 11" wide rear with a 50mm offset (17x11 ZR1, these are just inside the rear fenders on camaros).
Old 02-03-2014, 03:46 PM
DemonicZ's Avatar
Front:
using 9" with 56 as stock and new wheel is 9.5 with 40
it says inner clearance is 10mm more and outer clearance extend an extra 22mm
Rear:
using 11 with 50 as stock and new wheel is 9.5 with 40
it says inner clearance is 29mm more and outer clearance retracts by 9mm
Quick Reply: TSW Sochi
