Forgestar cf5
Forgestar cf5
I was thinking about ordering these in 18x10 possibly 18x11 in the back I seen a setup on here a guy had it on his camaro but they were 19s. Anyway my question is would those bolt right on or do I have to bring out the hammer lol I seen a couple website but they don't list the back spacing ect so if anybody has them an can help me out is appericate it
Location: Illinois, as close to "Normal" as I can get...
https://ls1tech.com/forums/wheels-ti...-trans-am.html
they have custom off set being a forged wheel... if you visit their website it gives the available offsets. use the offset calculator on 1010tires.com
use 9" wide wheel with a 56mm offset as stock wheel
then plug in 10" wide with maybe a 45 or 40mm offset for the front
11" wide use a 50 maybe 48 or something like that and just see what is says
some common maximums for camaros are 17x7 with a 0mm offset in the front and 17x11 with a 50mm offset in the back (just tuck in behind the fenders)
hope this helps
hope this helps
[QUOTE=Guitar;17998786]17x7 is small as hell for the front IMO. 17x9 is the lowest I'd go with. The 18x10 and 18x11 on Peel's TA are badass.[/Q
I said MAXIMUM 7" wide with 0 offset. I'm not saying to run them just a MAXIMUM.
