Weld RTS 15x9 with 5.5 backspacing
Old 02-05-2014, 07:29 PM
chevydude's Avatar
Default Weld RTS 15x9 with 5.5 backspacing
I would like to see some pictures of Camaros with a set of WELD RTS 15x9 with a 5.5 inch backspacing. And with 275-60-15 tires. Thanks!
Old 02-08-2014, 10:09 AM
chevydude's Avatar
Not really finding the info I'm searching for so I went ahead and ordered the 15x9 with a 5.5" backspacing. I already have the fronts and they are 15x4 with a 2.25" backspacing. Will post pics as soon as I get them on.
Old 02-08-2014, 11:14 AM
1nastyss's Avatar
I hope your rearend is narrowed
Old 02-09-2014, 12:35 PM
chevydude's Avatar
I actually took the wheel off this morning and did a lot of measuring and called back and changed the order. So I ended up ordering a 15x10 with a 7.5" backspacing. If I measured correctly they should fit nicely. (fingers crossed)
Old 02-12-2014, 04:45 PM
chevydude's Avatar
Default WELD RTS 15x4-2.25 BS 15x10-7.5 BS
Ok as promised here are some pictures with the weld rts wheels. And they fit very nice.
Old 02-12-2014, 05:00 PM
chevydude's Avatar
ONE MORE TIME!!
Old 02-12-2014, 05:02 PM
chevydude's Avatar
Old 02-19-2014, 01:13 AM
Firebirdmuscle's Avatar
Do the fronts stick out any? And are they low pad since the 15x4 is 2.25
Old 02-19-2014, 08:22 PM
chevydude's Avatar
Yes they do stick out a little but it's not real bad. But I would prefer them to be in more. And yes they are low pad. If you want the front wheels in more I would suggest going to a wider wheel. Hope this helps.
Quick Reply: Weld RTS 15x9 with 5.5 backspacing
