abs traction and brake lights
Just put bigs and Littles on my 02 trans am and while driving down the street, the abs inop, traction control, and brake light came on. Will this cause any problems besides being annoying and can they be tuned out?
Is this what you are seeing? (The brake light is on because my E-brake was up)
Mine was a Bad Rear End ABS Sensor. I would look there first. And I drove mine like this for a full month before getting it fixed. It never caused me any issues besides being annoying as hell.
The tires are too far out of size from front to back. The OEM allows a certain amount of difference for tire diameter but obviously you have exceeded that so it is causing the ABS system to fault and turn off. It doesn't understand different tire diameters. No, it cannot be tuned out, you have no ABS as long as those lights are on. The only way to get rid of the lights is cover the bulbs/LEDS up or desolder them from the circuit board in the dash.
I have this as well. Anyone have a pic of the rear end ABS sensor? Or can tell me exactly where it is? I was told it could also be a wheel speed sensor? My tires are 275/40 all around so I know it's not that
On my setup, the reason I didn't go with the 325 size Mickey Thompsons in the rear is because they would have been 28" tall and every well likely caused ABS issues. Anytime there is a big, less than an inch, discrepancy between front and rear tires, the ABS issue will arise.
