18x10 offset questions
Looking to get some ccw t10. Looks like in order to get the 2 lip all around I have to go with 10" wheels. Any recommendations on correct offset to run these on the front and back. Any clearance issues to worry about with a 10 up front. I don't want the staggered look, I want the same wheel front and back. Also any opinions on nitto 555 in 275's on a 10" rim. Thanks
I had 19x10 C6 rims at one point all the way around. I ran a 275/35/19 tire and it fit the rim just fine and I had no rubbing issue (275 is the smallest recommended tire for a 10" rim). As far as correct offset, check the sticky at the top of this forum. I had a run a 1.25" adapter/spacer since the stock C6 rims have a 79mm offset...
