17x9.5 front wheels, what is a good tire size
Old 05-12-2004, 08:13 AM
frey51's Avatar
Default 17x9.5 front wheels, what is a good tire size
I know I know but I want some personal opinions. I have 17x9.5 front and 17x11 in the rear. I dont know the offset but they are the same if that helps. I have 235/45/17 in the front right now, which dont fit the rim completely, rim lip sticks out farther than the tire. What is a good tire size for the front with this wheel size.
Keep in mind I am currently stock ride height, but will be getting hotchkis 1 inch lowering springs soon after the new tires so I want front tires that wont rub on a sharp turn and so on. Ordering tires in the next few days and need this info asap. Thanks in advance
Fry
Old 05-12-2004, 08:30 AM
Casper9T9's Avatar
275/40 is what I run on my 17 x 9.5s.
Old 05-12-2004, 09:26 AM
frey51's Avatar
are you at stock ride height, or do you have a drop?
Old 05-12-2004, 10:45 AM
Casper9T9's Avatar
Stock ride height. I'm also going with those Hotchkis springs, and I don't see it being a problem. I have a 52 mm offset.
Old 05-12-2004, 05:24 PM
10 Second Fun Car
jlrz28's Avatar
Im running 285 40 17 on the front and rear on 17x9.5 TT2s all the way around.
Old 05-12-2004, 07:51 PM
OctaneZ28's Avatar
Either size 275/40-17 or 285/40-17 will fit, but the 275s would be better to keep the stock tire height.
Old 05-13-2004, 02:39 PM
Xsta Z 28's Avatar
275/40zr17
Quick Reply: 17x9.5 front wheels, what is a good tire size
