What tire with my combo
Just swapped into a 2002 Camaro Ls6 with several mods. Currently it makes peak power 5500-6000 on the dyno sheet (on motor). It has a 4l60 with a 3500 stall. The 10 bolt has 3.73 ratio gears. I have a Currie 9" with 4.11 gears waiting to go in. The car is set up with a 100 shot on a wot switch, which I plan to change to a progressive setup.
Now to the question what diameter of tire should I use with the 9" for best performance on a 1/8 mile track?
