15x10x5inches of backspace
Just got my 4.5 bs wheels in. Mine is -3 off each side. I don't see how folks are running 5.5 bs on -3 off each side. I have 325/50 and there no way possible on my car that the 5.5 would work without a spacer. A 5.0 bs would still in my mind be pushing it close. But every set up is a little different and I know people run both 5.0 and 5.5 bs with no problems. Hopefully yours will be one that doesn't give you any problems. Btw on the 325, it looks killer on a 15" wheel like stated above. It's really meaty.
I run a 295 on a 15x10 5.5 backspace. Rear is narrowed 2.5" on each side. I still have to run a 1/4" spacer to keep it from rubbing in hard corners.
I don't see how anybody gets away with 3" narrowed and a 5.5 bs either.
Note: Since the car is on the lift with the suspension hanging the upper part of the springs are not seated in the spring pockets and the entire axle is shifted towards the driver's side.
