17x11 rubber
17x11 rubber
I know this topic has been beaten to death but I cant find anything recent and I would like to get some pics as well, I see a lot of you guys run this set up.
I just ordered my zr1 17x9.5 and 17x11 wheels, and it seems like the only promising tire available for me, my needs, and my budget, is the nt05. (275/40/r17 and 315/35/r17)
My car is not a DD. I only take it out once in a while for some street abuse and don't plan on going to the track any time soon.
Anyways is there any other tire available in this tire size or wheel size that I should consider? Could I go taller?
Can anyone post pics of this set up?
Maybe a dumb question but how do DR respond in the twistys? I am considering running Nt05r in the rears. Is that going to kill me in the corners/spirited street driving?
R888 are an R compound road course tire. They will heat-cycle out if you use them on the street a lot, which means the overall grip level of the tire will deteriorate long before the depth of the tread gets too shallow. All of the people who I know that have run these tires (5 to 7 people who use their cars for autocross, track days) say they are junk and will not be purchasing them again. Honestly, the NT05 is a decent choice, also look at the Kuhmo Ecsta XS (more cornering grip than the nitto, shorter tread life). Unfortunately the tire selections for 315/35r17 is dwindling unless you want a drag radial.
I have been very happy with my NT-05's. Drag radials were better in a straight line, worse in all other aspects. If launching your car is not your primary need, the NT-05 would give you plenty of everything. They are going to be better than most street tires, just not drag radial level.
I am going to go with these or the nto5's.
a little off topic but I installed my rear wheel toady, http://www.oewheelsllc.com/Wheels_3/...2#.U0q2M_6PKM8
just to make sure everything fits.. and wow its not even close! looks like I am going to need a bigger hammer!
If I lift the car from the rear end and keep the bump stops, they wont rub on the wheel at all when driving?
yes I will be once the rubber is mounted, but my main concern is the actual inner fender. I am at stock ride height, and couldn't even get the wheel mounted flush to the hub with the suspension completely unloaded. I didn't realize how much hammering will be needed.
I have 17x11s with 315s but I also have a watts link. I barley had to do any BFH'ing, I have no rubbing at all. You will certainly need an adjustable PHB if not a watts link.
The tires will likely rub a little, so you will really only need to do very little BFH'ing to get them to not rub.
