Tire advice needed (steet/autox setup)
I need advice on what the best option is to run for a street/autox setup.
My original plan was to run 295/35r18 vredesteins or kdw2's on a 18x10.5 wheels all around. However, I feel that these tires wont be able to give me enough grip to be really competitive at my local autocross. I am in between the two options
1) Run 18x10.5's all around with nt05's or g-force rivals. The only downside is that this car is daily driven and I want tires that last around 15k. From my research, you can stretch these tires to that many miles but Ill be doing about 5 autocross events a year so I will probably get less mileage about of them.
2) Have a dedicated street setup and run 18x10.5's all around with cheap tires like sumitomos and then use my stock 10 spokes or 17x9.5 zr1's and run r-compound 285's all around.
Which do you think is a better option financially for those of you who autocross? Also, how long should I expect a set of nt05's or rivals too last?
LS1Tech Platinum Sponsor
The Rival wore very well in our testing on the AutoX. Dedicated track tires are not going to the best option on a value aspect. You will be faster of course. You can wear a set of R-Compounds out in a few weekends depending on the tire. My vote would be the Rivals if you get 15k+ for street and auto X thats really not bad.
It really depends on if you want to run a street tire class or not. I have done my own research and decided on Rivals for AutoX. I plan to try to fit 18x11 with 295/35R18 myself.
SCCA has a new class for muscle cars... Classic American Muscle (I think). If your car is modified this is a good choice I think. It is for street tires.
Brian
Brian
