Wheels for a 4th Gen with a 3rd Gen rear???
I changed out the rearend in my 97 Z to a 3rd Gen 9" rearend. Bolts right up, just 1.5" shorter on each end. Not sure what offset I now need with this setup. Want the wheels as wide as possible and put as deep a dish on them as I can.
Thanks,
Rob
Thanks,
Rob
Do a little math. 1.5"=38mm. Stock 9" wide wheels are 50mm offset. If you wanted the wheel to sit in the same place youd need a wheel with 12mm offset. Or a 0mm or slightly negative offset to be more flush with the top of the wheel well. 1010tires offset calculator is really helpful.
