Polishing not going well. Cloudy.
try doing an area without the power ball and see if it makes a difference. I usually apply polish with my bare fingers and buff off with a clean micro fiber towel. hope this works for you.
I deleted my post because I didn't read your's all the way through.
The power ball will leave some marring. To get it better I would suggest going with the Billet polish which is finer and a decent MF towel.
Adam's Metal polish is really good but the Billet polish is close and you can get it locally.
Hey I use to polish motorcycle parts and mothers polish is abraisive. You need to use a fine polish. I use a product call semi chrome is real fine and it has no grit. Use a soft tissue paper to rub it on and then use a soft buffing wheel to rub it in let the wheel do the work do not apply any pressure. after the semi chrome polish I use a high gloss polish rouge stick also apply with the buffing wheel you need to use a different buffing wheel with each steps . Hope this helps
So using a pad like the mother power ball (mini) is not what I want to use? What other kind of pad should I use? Polish by hand or by drill? If I polish by hand do I go in circles or in a back in forth line?
you can do it buy hand I rub up and down until it turns black. As far as the cloth wheel there hard and soft wheels buy . but since your rims are already polish. I would just use the soft wheel. You can buy them at sear hardware. I use the wheel with my dewalt grinder ( note I remove the grinding wheel and install the soft wheel pad lol). IF you used the wheel the polish come out better also check out eastwood the sell the six inch wheel. you can just do it buy hand
I polished the wheels on my last motorcycle all the way from a painted sand cast finish. Lots of sanding, but since you're already polished, it'll be a lot easier. I use a roto-zip with polishing wheels and rouge. I'd use the soft wheel and fine rouge and it'll come out looking like chrome. As big lou has said, a grinder will do the same thing.
You did strip the clear coat off those wheels first, right? Because if you didn't, metal polish isn't going to do anything at all. Does the polish turn black after a few seconds of scrubbing? If not, then there is clear coat on the wheels.
Edit, I can't read obviously because you said it is turning black. Not sure what else you can try doing. I had great luck with the Adams 1 and 2 metal polish.
Just a correction...The product you're referring to is 'Simichrome'.
It's really good stuff, and I began using it in the early 70s, when I got my first set of aluminum wheels. However, at least for me, it isn't as available as it used to be, at least on a local basis. Lately, I've been using a product called 'Blue Magic', as that's what the guys at CCW told me they were using.
To the OP, if your wheels are still looking cloudy, it's probably because there's still some residual polish on the wheels.
I didn't wet down the power ball I used it right out of the packaging. I'm using the paste kind of polish. I'll try a different pad and a different kind of polish. I used 3 different kinds of stripper to make sure all clear is off. I'll give it another go this weekend.
Ditch the powerball and polish them by hand. It's not that much more effort, really. White diamond metal polish and sealant is an excellent otc polish that can be used with a microfiber towel.
Captain Double Post
