Re-drill Ford bolt pattern....to fit GM. Anyone done this?
I'm wondering if the re-drilling moved the bolt position so far outward that it ran into the wheel itself. This wheel doesn't look like it has a lot of room to move until it hits the painted part of the rim.......
I know it's only about 6mm difference, but man it looks like it will hit the painted part of the wheel lug hole.......
Also, then the thickness of the lug on the stud might hit the lug hole wall.......
I had a machine shop re-drill some hubs on a thunderbird to to take mustang wheels and brake rotors. Worked like a charm. I would be leary of re-drilling or machining wheels out to fit.
You don't like these.......
I was gonna get these re drilled and widened to 11.5" and use 335 tires. Then have Strange cut 1" off each end of my rear axle to make them fit properly. Then mini tub it.
The wide dish area makes them look good.....this wheel would look good on my red TA.....with charcoal grey CETA paint.
I'll give it some thought.... Back in 2000, I bought a Lincoln LS for my wife to use as a DD. I was going to put the snow tires on the OE wheels, and needed some wheels for the summer tires. I saw an ad in one of the car magazines by the (insert wheel company name here) for these wheels, in a variety of lug patterns, the Lincoln included. Unfortunately, they didn't stock them in time for when I needed them, and right off the top of my head, I can't remember their name. But I'll try....
Thanks.....
I've tried to remember the name, but I'm drawing a blank. Problem is, my experience was 14 years ago, and a LOT of those wheel retailers have the term "replica" or something like it, in their names. I just can't remember what Replica this, or OE Something, was in their name....
arent these the wheels? I remember the owner of this car saying they were mustang wheels not sure. this was years ago when I was first new to this forum.
https://ls1tech.com/forums/10557714-post14.html
I was considering sending my rear end back to Strange......for just $150.00 cutting and $89.00 for new axles, they will send it back to me with 1.5" cut off each end and set up with the Ford bolt pattern......then these would fit perfect......
I really like the DEEP dish.....and the Anthracite will match my charcoal grey CETA paint.
