Does anyone here run neutral or square setups?
So, I have a great set of wheels, 18x10's + 30 on offsets, and I am questioning putting them on the TA....curious if anyone here has experience or runs non-staggered wheel/rim setups...and side not I hate and refuse to use spacers.
Thanks for opinions in advance, they are BBK compatible, currently on my 350z but going back to the 17#forged wheels there I believe.
Every car came with a square setup from the factory, so I and likely many others still run them. Stock rims are either 16x8 or 17x9 depending on the model. You would have to research if the offset and backspacing on your rims will work, or just put them on and see if they fit.
those wheels on the rear will most likely require some hammering of the inner wheel well with a +30 offset unless run with a spacer. not really sure on the front though, but best way to see is to put them on and see where it rubs if at all. and post some pics when you to to lol
