Widening a set of fikse fm5's
Depends on what you want the offset to be. If you put a lip on it, itll push the tires out and if you put an inner barrel, itll tuck the tire in. Very simple but make sure you know how everything is measured and what will fit.
Also they are about $300 a piece unless you can find some used ones (hit up Thatcher for some)
Here's the scoop on changing 17x9.5 to 17x11 with Fikse wheels made for our cars.
For 17x9.5 Fikse uses 7" inner barrel and 2.5" outer barrel.
For 17x11 Fikse uses 8" inner and 3" outer.
So you have a choice. If you want 11" out back you need to get 2 new inners and 2 new outers. If you want the look of 11", just get 2 new 3" outers and rock 17x10.
I know it seems crazy that the 11s look like they have a much deeper dish, but it's only .5" more.
