Wheel stud and lug nut combination?
So I have a Moser 9" with Moser axles, etc. The axles were shipped with standard 12x1.5 studs. The car came with longer studs when I bought it (on the stock 10 bolt) as well as 1/2" spacers. After installing the 9", the wheel wouldn't mount unless I took the spacers out, so I did. Now, the other day a stud snapped on the passenger rear so I'm forced to replace it (obviously). So I'd like to buy longer studs so I can run a spacer, but I have no idea where to start. I'd like something bulletproof so this doesn't happen again. The wheels are 18" C4 ZR1s. If anyone can help I'd greatly appreciate it, just so I know what to order. I'll also attach a picture of the wheel to give you guys an idea. The thickness of the wheel is about 1/2" (contact point between lug and axle). Thanks!
