Rear tires. Mickey or Nitto (pics)
I have both Mickey 305/35-18a nd Nitto 555R 335/30-18.
The Mickeys are 1/2" taller and the Nitto's are 1" wider. They both fit. The Nitto's actually fit the 18x11 wheels a little better.
Which ones to go with? Opinions anyone?
The verdict is in. M/T just fits the car better. The Nitto was a little too low pro for my taste and just didn't hook. The M/T simply hook much better with all things being equal. Both sets were heat cycled first. The M/T 305-18 is the same width as my old 315-17 M/T. I mean exactly to the mm as wide...
So far im very pleased with the et street2. It is the same compound as the et street one and we all know those hook. There are surprisingly very few pics of et street 2s, especially in a 305/18 setup.....which is why I posted. I know this because I was looking for info before I bought mine.
Don't get me wrong, the Nitto is a great tire and much better at handling. I was looking for more straight line hook than cornering. Gotta have pro's and con's...
Loving the M/T's.
Loving the M/T's.
i have never used the mickeys but I know my nitto's wear quite well on the street, but on an un prepped surface I will just fry them...I will probably be going to mickey or hoosier and try them next myself
tried everywhere from 17psi down to 10psi lower psi was worse for spin.. I should have just left at 17 and waited for some rubber to be put down. at 10psi I spun the wheel in the tire some too...not bad, a bit over 1/3 rotation they are nitto drag radials... when trying to put the power down on the street I am not impressed, but for an all around tire I guess they are pretty good, as long as not launching hard they do pretty well and seem to be wearing quite well... am sure a person can get several thousand miles out of them on the street with some drag racing in between. I don't put many street miles on the car anymore so a tire that wears fast is not a big concern for me... but getting it to stick with very little rubber on the pavement is.. at the track I am sure they will hook good though. I am going to 15x10 bogarts so I have some sidewall to help with absorbing some of the shock of launching a stick car, right now I am running the ss 17x10 inch wheels on the rear so not much sidewall on the 26" tires
