Pic request: 01 Stock SS zr1 wheels with adapter
Looking to put adapter in the rear of my wifes 01 SS when I lower it. Having a hard time finding a thread showing wheel adapters on stock wheels. If you are running adapter please post pic or give me a link. Also any additional info on what size, brand, and if you cut stock studs.
Thanks
Here is the car we picked up the other day
Thanks
Found this..
https://ls1tech.com/forums/wheels-ti...r-adapter.html
So if anyone has the ZR1 wheels and adapter please post pic up... Im going to order probably 1" h&r adapter.
I'd plan on rolling the rear fender lips with 17 x 9 with 1" hub spacers, just in case you do have clearance issues. H & R also makes a 20mm / .75" spacers #4085704 which will avoid any possible clearance issues with the fender lips. If you really have factory 98-02 Camaro SS 17 x 9, or factory 17 x 9.5" (C4, Zr1) wheels which have hollow areas between the lug nut holes on the back side then the 3/4" H & R hub spacers will bolt up with no clearance issues between the protruding wheel studs and the factory wheels.
LS1Tech Administrator
Received 1,489 Likes
Just an FYI, the ZR1-style Camaro SS wheel in the OEM 17x9", 50mm offset sizing with chrome finish was available as a Y2Y option through 2002. '98-'99 were the only years that this was the base wheel (in silver) for SS prior to the introduction of the 10-spoke in 2000, but they continued as optional in chrome. So the '01 car above could definitely have been optioned with the 17x9" version stock.
Do a one 1", I did that on mine all around bc I have the ctsv brake upgrade in the front so I had to run a 1" adapter to clear the brakes with the spokes. It looks way better than stock bc it eliminates the wheels tucked really far in look. I done the heater hose mod on the back and Viking coilovers in the front so at least a 1/2 drop. No issues. I ordered my adapters off ebay.
