10.5 on the front of a 96 camaro
I'm looking at buying new wheels can I run 18x10.5 with +58 on the offset on the front of the car was looking at 18x10.5 for all four corners will they fit
FYI, those wheels have too much positive offset for proper fitment on a 93-2002 F-body.
Your going to need spacers with that offset, just like 18" x 11" +50mm offset.
Furthermore, a +50mm offset would be perfect with 18" x 10.5" wheels.
In the rear you need to do all the same inner wheel well modification as you would with 18 x 11, +50mm offset wheels.
Futhermore, a +44mm to +50mm offset in the rear would offer the best fitment.
http://wheelreplicas.com/camarowheels-page-2 this is the wheels I was looking at they said there for a camaro
I use 1/4" hub centric spacers with my 17x11 50mm ZR1 replicas. You might be able to get by using the ones you found if you have at least a 1/2" spacer and longer ARP wheel studs, and then as previously stated all the mods typically used to make the 17x11's work (minor grinding on the spindle, sometimes rubs on inner wheel liner at full lock, sometimes rubs on sway bar arm at full lock, etc.)
Super Hulk Smash
I run a 9.5 +44 on the front. You can run a 10" or 10.5" wide wheel with a 40mm offset. There's plenty of space to the outside of the wheel. Not so much inside. Anything over 50 is going to rub the spindle. So you need spacers or the proper offset.
I run a 11 +44 in the rear. It's flush with the outer fender and just clears the inner fender.
