Just brought some wheels need help
Question is I need to know well I be okay if with wheels that have bigger stud holes on the rear wheels. The guy I brought the wheels from had bigger studs in the rear of his car. And he give me lug nuts for the bigger hole
Trying to make sense of your post (it was not written clearly).
First, I personally would not alter the holes for the lug nuts in the wheel. I am no expert on this, but it would seem to me this would not be safe just to begin with. If the wheels didn't fit, then they did not belong on there in the first place. I would find wheels appropriate for the studs (not modified) so you know you have good safe securement of the wheels on your car.
So you are saying the studs that the lugs go on are larger.. I can see that. But to do that he drilled out the holes on the rim. Agreed with above get one of the rims checked out but a wheel/tire shop?
