wheels for white camaro ss
Old 12-04-2014, 09:00 PM
1SCKLS1's Avatar
Default wheels for white camaro ss
not sure if i should go billet specialties or weld rts wheels does any have pictrues of either wheel on a white camaro... and how is fitment was thinking about going 15 inch all around because it is cheaper thanks for the help
Old 12-04-2014, 09:26 PM
stealth355tpi's Avatar
Old 12-04-2014, 09:31 PM
1SCKLS1's Avatar
Wow thanks bro are u runing 15s all around? and any problems with the calipers fitment
Old 12-04-2014, 09:36 PM
They were fbody specific 15x4 15x10. I sold them awhile ago now but from what I remember the rears fit fine once the bump stops and mounts were cut off. The fronts I had to just very lightly grind the caliper to make fit. Might to able to run a thin spacer instead. Seems like most people get away without anything and only a few had to make adjustments.
Old 12-04-2014, 09:49 PM
1SCKLS1's Avatar
perfect thanks for your help man how did they rid with them?
Old 12-04-2014, 09:50 PM
1SCKLS1's Avatar
and what were the tires sizes thanks alot
Old 12-15-2014, 10:32 AM
2001_Z28_FUN's Avatar
2001 Camaro Z28 here, running 15x3.5 front draglite, 15x10 rear draglite, no spacers at all, just need to spend some time gently shaving the Brake calipers all 4 of them, takes a little while to get them perfect but looks great and performs great when all done. hope this helps some : )
Old 12-20-2014, 07:17 PM
compton-z28's Avatar
love the weld draglites man
Quick Reply: wheels for white camaro ss
