M/T ET street radial pro p275/60r15--- says to use 7.5-9.5" rim... use 10" rim?
M/T says to use 7.5-9.5" rim on the p275/60r15.....
i see guys running 10" and larger....
whats up with this?..... ok to run 10"?...
Need help!!!
thx
Need help!!!
thx
I would imagine the reason that MT specifies a more narrow wheel has to do with the tire working so well on higher powered cars that it has a tendency to spin without a beadlock on a wider wheel. When you squeeze a wide tire on a more narrow wheel you have a tighter seal against the bead of the tire making it hold better and less likely to spin on the wheel.
Thanks for all the replies...
I am thinking I should be ok but will try and if the tire moves at all I guess I will have to get a bead lock....
I have 921 rwhp now and its on a 4530 lb (with driver) car...
thanks again...
thanks again...
