Lug nut?
Lug nut?
So i tried on my new Rushforth wheels the rear wheel studs have about 1" of lug engagement but the fronts wil have right around .625" or 5/8" i know the rule is 1.5x the bolt diameter which the studs are 1/2" so they should be 3/4" engagement will this be a problem?
I looked to see if i could find a bit longer screw in stud for the wilwood brakes but the next longer size is 1" longer which would also require longer lug nuts!
Closed and i dont care how well you cut them you can tell i want a factory finish on the ends. ARP said cut the longer ones down but dont get them hot enough to change color or use a tap to clean the threads which was a short answer also! I cant believe no one makes 2.5" studs!
