cutting off the bump stop tabs
had the car for 2 years now and the bump stops have never been there. I have 17 x 11 zr1s on the way so I'm going to cut off the tabs
Anything I should worry about after doing this? I'm getting new suspension as well, slp bilstein shocks and strano springs so I don't think the car should bottom out for any reason..
Relocating the bump stops is the best and right way to do it(like RAMPANT did). Otherwise you risk damaging the shocks, tires, or other moving part that could cause or receive damage colliding with the undercarriage when the rear shocks fully compress.
well wheels are on, fender clipped the driver side tire a little I didn't think anyone ever needed to roll their fenders with these??
And a little bfh was done on drivers side, my lca's n ph bar still aren't here though which should help I hope because no one around me has a fender roller
air bags work too....
Yeah their a OK Band-Aid if you removed the bump stops, but still not a replacement for bump stops. Using Air bags that sit in the coil springs end up changing the spring rate to a higher rate which kind of defeats the purpose of getting the Stranos because of them have the best overall spring rates.
I'm no welder but what RAMPANT did is by no means complicated. It's actually the simplest solution I've seen to date, but it does need to be welded on. Which I would think any good welder could easily do in a fairly short amount of time.
Imo, if you're willing to cut off the factory bump stop mounts, at least make a effort to do it right and relocate them, it's not rocket science.
lol got it all taken care of and the wheels fit, thanks guys
ps LPE can't wait to see what ya do with the ride this year, I've told ya before but again that thing is sick!
The 93-2002 f-body has a lot of fender lip(mine did, about 1") that sticks inward toward the tire sidewall. So as another option if you have a die grinder with reinforced cut-off wheels, and you feel confident with your ability, then you can also cut a large amount (about 3/4) of the lip off. Just make sure to smooth the cut and give it a good coat of touch-up paint.
Off topic, yes, but what springs did you use with those (GC?) weight jackers?
Are they flat ground on top or did you find a full size pig tail spring somewhere which will work with the stock isolator/perch??? (Obviously they are pig tails on the weight jacker end.)
