Which Slicks For M6 WS6 Making 450+ RWHP
Old 07-22-2015, 12:56 PM
Rise of the Phoenix's Avatar
Default Which Slicks For M6 WS6 Making 450+ RWHP
Guys, my Mickey Thompson ET Street Radials will need replaced here soon, and being a M6 car, I've been thinking about making the switch over to a slick. I drive the car mostly on the street, but want to be able to hook up good for street racing, and the occasional trip to the strip. Car should be making 450+ with modifications that will be underway here soon. I have no clue when it comes to slicks. Are they okay to drive on the street? The car only comes out on nice days, so it sees no rain or snow. Stiff wall slick, not a stiff wall slick, I'm lost. Help me out guys. Also feel free to post up links to specific slicks.
Old 07-22-2015, 01:31 PM
HCI2000SS's Avatar
I'd only consider slicks if the car sees way more track duty than anything else. That's just my personal opinion
Old 07-22-2015, 01:39 PM
Zmg00camaross's Avatar
I run M/T ET DRAG 28/10.5 stiff wall. Forgot the part number but will have a S at then end of the number indicating stiff wall. I also ran Hoosier qtp and were nice, also DOT approved. Slicks you will have a bit more wishy washy feel they move a bit. Takes time getting use to it but it's fine. They won't last long on the street. Another option but not the best is the M/T drag radial pro, they also have a Pro bracket and here it is a great tire.
Old 07-22-2015, 02:02 PM
https://www.mickeythompsontires.com/...=BracketRadial
Is this the pro bracket radial you're talking about? How does this tire differ from a Mickey Thompson stiff wall slick, or the Hoosier QTP slicks?
Old 07-22-2015, 04:03 PM
dckmn52's Avatar
http://www.mickeythompsontires.com/s...?item=ETStreet
regular ET street. manual cars hate radials. ive been leaving at 6000 on mine and theyve been better to me than my pissed off clutch!
I use 26x11.5s and swap them out for track but theyre okay for street use if its minimal driving. around 18psi and i dont have any wandering feeling ususally associated with a tire like this.
Old 07-22-2015, 04:18 PM
I didn't think of this, but what kind of tire should I run up front? I don't believe you can run a radial up front and a non-radial in the rear. My Dark Stars up front are 17x9.5's. I doubt they make a non-radial tire to fit that size wheel.
Old 07-22-2015, 05:50 PM
It's just a really good radial tire and would be far more streetable then a slick. As far as mix and matching I never had a issue.
Old 07-22-2015, 06:03 PM
dckmn52's Avatar
Im with Zmg on this one as far as mixing tires goes.
Haven't had an issue and haven't been yelled at on the track yet, and i run a 245/50 street Pirelli on the front.
Id check with your local track officials and see what they say. On a street driven car they might not have an issue. A tube body 8 second bracket car might be a different story.
Old 07-22-2015, 08:03 PM
Sounds like this will be my best option, given my current front tire setup. My ET Street Radials work good, so if this tire is better, sounds like a win to me.
Old 07-22-2015, 09:05 PM
RAMPANT's Avatar
I had good luck with the QTPs, went 1.48s with Koni shocks and an M6 510 rwhp. A few times it dead hooked at over 6000 rpm dump. If you have a loose front shock they should hook up even better. Never did better than a 1.7 on a DR.
Old 07-22-2015, 09:45 PM
It's a ok compromise. If your not max effort I wouldn't run a slick on the street all the time. I think the pro radial or pro bracket would be a ok compromise. Especially if it sees more street duty. Just will not be record setting 60ft times.
Old 07-23-2015, 08:00 AM
I'll probably try the MT Pro Brackets and see how they do. I can't kid myself, the car sees way more time on the street than it does on the track, so I think those will suit me fine.
On a side note, I've always hears that a M6 car should run a slick, while an automatic car works better on a radial. Why is that?
Old 07-23-2015, 08:11 AM
Photochop's Avatar
If you street drive the car alot I'd go with a hoosier drag radial. They'll offer more stability on the street from the radial construction, but have a thinner sidewall to promote flex.
It's also unsafe to run a radial up front and a biased ply tire in the rear. I've done it, and it makes the *** end of the car feel like it's going to come around you past 500ft out. Some never have an issue, I personally would never do that again.
Old 07-23-2015, 08:34 AM
guppymech's Avatar
This article is short but full of good info:
http://www.superchevy.com/how-to/081...ag-tires-tips/
Old 07-23-2015, 09:12 AM
In short manual Trans are violent off the launch and a radial doesn't recover like a slick. Even a stiff wall slick has more give then a radial. From what I hear at this time ppl prefer the M/T pro series over the Hoosiers at this time. No experience with either.
Old 07-23-2015, 09:18 AM
scotty2000ss's Avatar
Not trying to be an *** but do you do alot of street racing? Maybe your best bet is to grab a set of wheels and tires for strip only?
Old 07-23-2015, 10:07 AM
Not a ton, but plan to do more after I change the setup up this winter.
Old 07-27-2015, 06:37 PM
k_garretson23's Avatar
DOT hoosier qtp best tire period
Old 07-27-2015, 07:14 PM
Better get a new rear before tires haha.
Old 07-30-2015, 02:47 PM
Yeah, I need to address the rear before long.
Quick Reply: Which Slicks For M6 WS6 Making 450+ RWHP
