5x120 Hub Centric Rings?
So I purchased a set of 5x120 bolt pattern wheels. I havent yet test fit anything but I was told I would need Hub Centric Rings because the original bolt pattern on F-Bodies is 5x120.6 mm...
I'm not looking for any spacers, where would I find just the Hub Centric Rings I need and more importantly, what kind and specs will I need?
Edit: After doing more research it appears this is only important if the hub bore is larger than the actual wheel hub.
What is the diameter of the hub on a 99 LS1 Camaro?
The Hub bore of my wheels are 74.1mm
Will I need Hub Centric Rings?
I'm actually looking at the same thing for my TA.
Hub centric-rings is the site I'm looking at.
I haven't measured mine yet but I do have aftermarket corvette rims so I'm hoping there is a gap and the rings will fix my vibration issues.
will I need a hub centric ring for the remaining 3.8mm space?
Edit: Is it 70.3 for front and rear or just the front?
Will this work?
http://us.hubcentric-rings.com/size-74.1-70.3/
Will this work?
In fact, back in '99, when I ordered a set of CCW wheels for the car, they asked me if I had the different sized hubs on the car, so it was pretty well known....
I have a 99 Camaro that I got hubcentric rings for and I got them with the I.D.(inner diameter) being 70.3 for all four corners. I got them from the website Smoove mentioned and I have had no issues.
