Suggestion for rear wheel/tire
I am currently rolling on my stock 17x9's but as I add more engine mods, my ability to tear through street tires also improves. Anyone have some suggestions and hopefully pics of a decent drag rear wheel/tire that would look good with my stock fronts? Budget is ~$1000.
Thanks in advance
Thanks in advance
Nitto 555 Extremes all around. Non drag radial. Great dry and wet traction......
315 in the rear on the factory rims. I did that for 15 years, works perfectly. Wears perfectly. lasts 15,000 miles.
Stock size tires in the front.
Should only spend about $650.00-$700.00.....
....If you really want a drag radial that will only last 5,000 miles.....Nitto drag in the rear, 315 size.
Pontiacerator
You might try a stock size set of Mickey Thompsons on your stock wheels - as long as you don't plan to drive in the rain. If you want a serious upgrade, there are numerous five spoke drag wheels that would look decent with your fronts. I'd be looking at 15's with a 275/50 tire.
I doubt suspension mods will help you at this point.
