Need to replace this rim
Someone hit and ran my Camaro and I need to replace the rim but I'm having a really rough time finding the exact one
My rear tires are 315/35/17 and the rim width measure d 10.5 inches and 4.5 inches between the lug nuts. I found an American racing rim that's very similar but has a different wheel cap and I found the exact same style rim but I can't it in 10.5 in width. Any help is appreciated.
LS1Tech Administrator
Received 1,471 Likes
That is a Torq Thrust II wheel, and is likely 11" wide (I don't think they ever made a 17" diameter TTII in a 10.5" width). If your Camaro has a factory GM rear end, then the bolt pattern (space between lug nuts) is actually 4.75".
I called a place and they said it would just break, but thank you!
http://www.bbwheelsonline.com/americ...et-VN50571163/
this is the correct one I need right? will someone please confirm?
thank you guys for the help it was much appreciated. I took it off and measured it the width is 9.5 backspace=5in and my offset is -6mm. I'm going to order the rim with these measurements and hope it all lines up. thank you
Also, after doing the research on my wheels I came across info telling me my current setup is unsafe,. I'm running these 17x9.5 on 315/35/17 nitto 555 dr should I just replace the back 2 wheels with 17x11s?
