Need Help identifying American Racing Torque Thrust 2 wheel size
Old 03-19-2017, 08:36 PM
Fullblast's Avatar
Default Need Help identifying American Racing Torque Thrust 2 wheel size
These are the wheels and tires that came on the car when I bought it.
The rear has 275/40/17 Falken tires and the lip of the rim sticks out past the tire, and also looks like the contact patch is not as wide as the rim, almost like it's stretching to fit the wheel.
I know you need to take the tire off the wheel to measure properly, but I put a tape against the outside of the inner lip to the outside of the outer lip and it reads about 11 3/4- 12"
Are these 11" Torque Thrust 2 wheels?
Can I fit 315/35/17 or 295/45/17 tires on these wheels?
Also my front wheels measure about 10 1/2" or so. Are these 9.5 inch wheels? They have 245/45/17 tires on them and they are not quite closing the lip either, but don't look near as bad as the rear.
Any help would be greatly appreciated. I need new tires for the rear and need to buy a front wheel because it's damaged and leaking air. Thanks.
Old 03-20-2017, 07:28 AM
leadfoot4's Avatar
Generally speaking, the beads, which aren't counted when measuring the rim width, are 1/2" in width. Therefore, if you're measuring the wheel "outside to outside", subtract 1" for the beads (1/2" on both the front and back), and that's your rim width.
So, if you're measuring roughly 12", outside to outside, you most likely have an 11" rim.
Old 03-21-2017, 10:54 PM
Badazz 97 TA's Avatar
Those tires definitely do not fit that wheel at all. I would say it's safe to assume there at least 10.5 inches.
Old 03-22-2017, 07:52 AM
Fullblast's Avatar
I'm thinking they are 11 inches, because American Racing only makes them (that I can find) in 17s are 17×7, 17×8, 17×9.5 And 17×11.
Old 03-23-2017, 01:57 PM
bad_408_vert's Avatar
I just picked up same set but with no tires.
fronts are 17x9" and rears are 17x10x5" in actual measurement.
Old 03-23-2017, 02:36 PM
Fullblast's Avatar
Really? Where did you buy them from?
The only sizes I can find are 17×9.5. And 17×11.
If they are 17×9 And 17×10.5, I should be ok with 275/40/17 tires for the front and 315/35/17 for the back right. I want to use Mickey Thompson street comps.
Old 03-23-2017, 02:52 PM
Fullblast's Avatar
I just called American Racing and they sell the 2 piece wheels in 9" and 10.5" and the one piece are 9.5 and 11". They said the one piece were the more common size
Old 03-24-2017, 07:38 AM
I'm going with 275/40/17 tires in front and 285/40/17 in rear
Old 03-24-2017, 10:14 AM
Fullblast's Avatar
I have 275/40/17 in the rear and you can see that another 10mm is going to go no where close to closing that wheel gap. The tire looks like it's stretched on the wheel.
I can't quite tell if they are one piece or two piece. AR said there's a very small gap on the inside of the wheel where they connect but I can't tell for sure.
Old 03-25-2017, 07:23 AM
leadfoot4's Avatar
Originally Posted by Fullblast
...................I can't quite tell if they are one piece or two piece. AR said there's a very small gap on the inside of the wheel where they connect but I can't tell for sure.
Look at the inside of the wheel, where the center meets the rim. Do you see a welding bead? If so, it's a 2 piece wheel.
Old 03-27-2017, 07:01 AM
z28a4's Avatar
If you pull the wheel off, theres probably a part number somewhere on the backside of the wheel.
Rob
Old 05-07-2017, 09:35 AM
Fullblast's Avatar
*Note...my drivers side front wheel is curb damaged beyond repair and I need a new one.
I pulled the wheel off the front and there is a welding bead on the inside. I'm assuming this is a 2 piece wheel. However this 17×9.5 2 piece wheel is $340 at several places!!!
The part number on the inside is ARE-505 and I can't find that number anywhere unless they changed it to VN505, which are crazy expensive.
You can buy 2) brand new torque thrust 2s. 17×9.5 for $315
So If one wheel is truly that much, what is the proper backspacing I need for 2) 17x9.5 wheels up front?
Or can I just buy a 1 piece wheel and will it match up to the 2 piece?
Old 05-08-2017, 04:25 PM
Fullblast's Avatar
So can anybody tell me if I have 3 wheels that are 2 piece, can I use a 1 piece wheel if it has the same backspacing? I shouldn't make any difference right?
Old 05-10-2017, 04:17 PM
leadfoot4's Avatar
Wheelsforless.com has the wheels, Torque Thrust IIs, "on sale" right now, for $165............
Old 05-10-2017, 04:22 PM
Fullblast's Avatar
Those are 1 piece wheels. I have 2 piece wheels all the way around. Those wheels have a 7.06 backspacing. Is that the proper backspacing?
*I called American racing and they said i could use a 1 piece as long as the backspacing was the same as my 2 pieces.
Quick Reply: Need Help identifying American Racing Torque Thrust 2 wheel size
