What 315/xx/18 tire brand for good traction on street?
Old 03-26-2017, 09:49 PM
Nyvark627's Avatar
Default What 315/xx/18 tire brand for good traction on street?
Looking to put 315s all around on the car but can't find a good kind to go with. Must be on an 18" rim in order to fit over my brakes. I could go to a 19" if absolutely necessary but not sure I want my tires that tall..
Was originally looking at Michelin pilot super sports, nitto nt05 or hankook rs3 but none of these go wide enough on 18" rims.
These will be used on the street only, doing lots of corner carving, no track time. Car should be making upwards of 1000whp so looking for something sticky enough to keep good traction at high speeds. A summer only tire is fine, don't plan on driving while it's raining so tire doesn't have to have good wet traction.
Also, for a 315 tire would a 10.5" rim work or is an 11" required?
Old 03-26-2017, 11:22 PM
dave04da's Avatar
I have Toyo proxes in 315 35 18's on 10.5" rims and they hook awesome on the street. Its about the only tire you can get in a 315 on an 18 rim.
Old 03-26-2017, 11:52 PM
Super Hulk Smash
JakeFusion's Avatar
Toyo R888s...
Old 03-28-2017, 04:40 AM
The Batman's Avatar
How much mileage would you like to see on one set of street tires?
Old 03-28-2017, 06:19 AM
Heat Seeker WS6's Avatar
I'm looking at the BFG Rivals
Old 03-29-2017, 01:26 PM
Nick.H's Avatar
Originally Posted by JakeFusion
Toyo R888s...
No no and no. Those are terrible for hooking up with any kind of power. This dude is gunna be making over 1k whp.... needs a drag radial. R888's were like driving on ice
Old 03-29-2017, 02:46 PM
black sky's Avatar
I believe the OP stated ......Street only, higher speed corner carving, and no track time. That really does not sound like drag radial territory. Have you ever tried corner carving with a squishy drag radial? It's actually quite unsafe. The R888 would fit his needs as jake stated. Especially in the size the OP requires. Not to mention more stability and plant by not having mismatched tires front and back. Not as much in diameter, but more in size, sidewall, and compound. Speaking strictly in a road race/handling application. Just my opinion
Old 03-30-2017, 01:45 AM
Nick.H's Avatar
Musta missed that part lol. My mistake. Read the 1k hp and threw me off. I've seen a lot of people in this section lately recommending those when they're not a good option.
Old 04-02-2017, 10:32 AM
2JAWZ's Avatar
What are opinions about a 315 on a 12" wide rear wheel?
Old 04-04-2017, 08:27 PM
Super Hulk Smash
JakeFusion's Avatar
The only downside to the R888 is the noise.
But it's going to hook a lot better than a real street tire. Might as well just give up if you want to use a regular tire.
Quick Reply: What 315/xx/18 tire brand for good traction on street?
