Were to get a set of front skinnie's?
Old 08-14-2004, 08:47 PM
2_wacko's Avatar
Default Were to get a set of front skinnie's?
I am in the market for a set of front skinnie's but don't want to go threw the trouble of having to grind the wheel's. Were can I get a set and not have to grind or go threw any trouble to get them on?
Old 08-15-2004, 01:25 AM
Bad Blu Formula's Avatar
Either you can go with Convo Pros which don't require any grinding but are very hideous, Pro Star XP's which are actually 16s and don't require grinding, and finally you can go to SJM over in the sponsor list and chose a nice set of Bogarts. The Convo Pros and Weld Pro Star XPs you can usually get at Jegs or Summit racing.
Old 08-15-2004, 10:10 AM
GM Muscle's Avatar
You can go with the regular 15" Prostar with a 5/16" spacer in the front and not have to grind anything. But if you eventually buy Prostars to match in the rear you will have to do alot of grinding to get them to fit.
Old 08-17-2004, 03:20 PM
Solid's Avatar
Bogarts all the way, that way you wont have the same wheels as 50 other cars in your area, especially with the anodizing SJM can do to them when you order like I had done to mine.
Old 08-18-2004, 12:41 PM
1fastWS6's Avatar
Centerline Telstar. Cheap, no grinding, uses stock type lugs, 5/16 spacer req'd.
ProStars are a HUGE PITA to swap on/off for track days. That's why I sold mine.
