18X10.5" black zo6 reps w/rivets not doable?
Says in the sticky that 53mm is about the max. all ive seen is 58mm offset. So i guess i have to go with the 18X9.5"s. maybe im missing something
Customizing Director
I have 18x10.5's in the rear with a +58 offset. They should fit the car just fine, but you may have to use a hammer and pound in a few area's of the inner fender to prevent it from rubbing (very small area's where it actually does). You can also run a 1/4 inch spacer in the rear which should prevent that.
I have a set of these on my car, 17 by 9.5 up front, 18 by 10.5 in back. I'm sellin them with tires for 1200. I like the look of the on my black camaro with the RS body kit. I am just doing a full out drag car now and dont need them. PM me if youd like to purchase.
18x10.5, 53 mm offset on all four. 295/35/18 on back, 285/35/18 on front no rubbing, no spacers. Very tight on front but they do fit. Dont think a 58 mm offset would fit but i suppose you could use a 5 mm spacer to make it work.
YEa, 53 is safe, but some cars accept more. I had the 18x10.5 all around with 56 offsets at one point. I was fine with 275-35 & 295-35 and I was lowered. 58 would most likely need small spacers up front...id just run the 9.5s if thats the case
