DR's on 18" BC Smoothie II's worth it?
Old 08-22-2004, 03:38 PM
delusion's Avatar
Default DR's on 18" BC Smoothie II's worth it?
Hi, i am just wondering, is it worth the money to put 18" nitto drags (285/35/18) on my 18" x 9.5" smoothie II's? I know these wheels are heavy, how much of a difference in my ET will these wheels make as opposed to stock 16" salad shooters with drags?
I really like the look but if it is making a big differnce in my ET i am willing to swap em to something lighter.
Old 08-22-2004, 03:45 PM
fattdaddyLS1's Avatar
Get the BFG G-force DR!
Old 08-22-2004, 03:49 PM
delusion's Avatar
I would but this car will be my daily driver, and i heard those are pretty bad in the rain. But is it worth spending the money on drag radials for these 18's?
Old 08-25-2004, 11:05 AM
delusion's Avatar
Old 08-25-2004, 01:32 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
BFG's are better in the rain than nittos. nittos are horrible in the rain
Old 08-25-2004, 03:48 PM
black_z's Avatar
I would just swap out to 16" for track duty.
Old 08-25-2004, 04:15 PM
blubyeu2000's Avatar
i will trade you my 2000 ws-6 17s for them if they are too heavy for you
Old 08-28-2004, 11:34 AM
DrkPhx's Avatar
It depends if you hit the track alot and want to maximize your ET's.
When I was near stock I saw a very small 60-ft and ET difference between 16" DR's and ET Streets. The more power you have the more the need for a stickier tire like an ET Street. It is nice to drive to the track with DR's, run and drive home without changing tires.
My 18x9.5 chrome C5's with Michelin Pilots weigh 53-lbs each. My stock 16" chrome rims with Nittos weighed 42-lbs each. My 16 Prostars with ET streets also weigh 42-lbs each. You can see the huge difference in weight between the two (I'm sure the salad shooters w/tire weigh around 40-lbs).
Hope this helps.
Old 08-28-2004, 11:35 AM
DrkPhx's Avatar
Are you comparing drag radial to drag radial? If so, the Nittos are much better in the rain.
Old 08-30-2004, 03:18 PM
Quick 99's Avatar
I had that exact setup, i thought it was worth it on the back because it gripped well, but i would just get some normal tires for the fronts and save some cash but i liked it
