Question on Weld Drag Rims
I liked the looks of the AlumaStars and the Magnum Drags and wondered if you can run them on an F-body and if you can run them on the street or not? I acutally saw someone running these on ESPN and thought they were the first drag tire combo I really liked. Of course they are probably a fortune and need mucho grinding but I guess I'd ask anyway.
Anyone got any pictures of either of these on an f-body?
minus the gold centers and bead lock
OR
with these up front
OR
with these up front
15X10 and 6 inch BS with a 3 inch narrowed rear end. They are MUCH lighter then a pro star. In the pictures the car is shown with a 275/60/15 MT Drag Radial tire.. 28 inches tall
yeah... now I was wishing I had the Moser shortened when I bought it after seeing those...
Can you get them in something a bit more street friendly so you can swap back and forth or do you have to go ***** out with that setup?
This might be retarded but do you drive that on the street much (if at all) with that setup?
damn. i have a moser 12bolt stock length. do you have studs in the rim and bead?? would that setup still work if i got the 15X10 with a 7.5 BS? is your front a 15X3.5 and a 1.75 BS?
Johnny5, no street duty for my car, the wheels are really for racing only and dont think they would do well on the street with a pot hole.. etc..
Mstngkiller, at the time of the picture, i just had 5/8th studs in the rear end and the wheels had not been drilled or screwed for screws. i am having the wheels "beedlocked" so that will solve that problem. I really dont know how well a 7.5 would work with a stock setup cause I never tried it.
