et streets or et drags
Old 09-13-2004, 11:21 AM
blu98ta's Avatar
Default et streets or et drags
With my setup I put about 350 hp on the ground. Should I get et streets or et drags? With that power do I really need et drags? I've heard stories of et streets getting squirelly at the finish line. Would I have to drop the psi that much that it woudl make that happen?
Old 09-13-2004, 01:32 PM
SJM Manufacturing Inc's Avatar
For the most part, traction is an issue. The ET drags will hook better, though if you’re planning on using them for street use, the ET streets may be a better compromise. The ET drags aren't DOT legal, if stopped by the police, you could get a fine...this is a stretch, though if he has stopped you to look for a reason for a ticket...this would be a good one: bomb:
Old 09-13-2004, 07:12 PM
tump's Avatar
I dont see 12 bolt in your sig?....My ET Streets will Dead Hook on my 6 speed at 6000rpm clutch dump, what more could you want. P.S. I have a broken Strange 12 bolt to prove it "33spline with SS-posi unit".
Old 09-13-2004, 10:15 PM
procharged's Avatar
tump, what kind of et streets are you using?
Old 09-13-2004, 10:37 PM
blu98ta's Avatar
so with my mods would et streets work for me?
Old 09-14-2004, 01:56 PM
blu98ta's Avatar
will 26x11.5x16 et streets work on a factory 16x8 rim? Would yall suggest doing this? Please let me know ASAP because I have an opportunity to buy them and I need to know.
Old 09-14-2004, 07:19 PM
next's Avatar
Yes they should hook for you.
Old 09-15-2004, 08:34 AM
blaSSt's Avatar
I run 26x10.5x16 ET Streets with 360+ to the ground. I can't come close overpowering the tires.
