Which wheels??
Which wheels??
I am in need of some slicks so I in turn need wheels. What is the advantage of running something like a draglight over just a stock wheel or something similar??
Thanks in advance,
Jake
Thanks in advance,
Jake
Weight is a huge factor of rims. I can take a few tenths off my car easy by swapping rims from my 19s to 16's. If all you want to do is go down the 1/4 fast then run 15" Draglites and skinnys up front.
there's a bunch of posts I recently commented on regarding weights and fitment issue. Bogarts are the best choice if you want the best.
To say you can loose .2 by going to Bogarts I dont' believe is too much of a stretch.
Not at all. As I stated above, a 9 lb difference (per wheele) netted me .3.
